harrys |
towing my self |
Yep, It happend to me this weekend. One of my rollbacks overheated. When I checked it out all the water was in the oil pan. So i had to pick it up from my
drivers house and took it to my lot. On monday I will tow it again to a shop to get it fixed.
MOMMASone |
oopps i hope that DT466 not to bust your driver horns but did he watch the gauge? My guess it was a water jacket or seal around one the cyd heads ,,,,,,,That
mean in frame rebuild i had that happen to me with my 97 the motor made a grunt and i look and the gauge went up but funny thing when i stop it went down did
my tow and made it home and it turn out to be a water seal.
that was a 2 years ago.............still running strong,,,,,,,,,, TOM Good luck |
harrys |
all my drivers are good about watching the guages. It actualy overheated as he pulled into the neaborhood. The oil is still clean (not mixed with water and
sludgy) so i hope it didnt do mutch damage. Yes its a DT466 it only has 265,000 miles
opinions are like arm pitts, everyone has more than one and they all stink.
Underdog |
If it's a DT-466 it is probably the o-rings on the cylinder liners....... which, yes means an overhaul.
Stay Safe, Rich. |
MOMMASone |
That good along he did not realy over heat it as i ran for 80 miles on mine with the bad o ring and i kept the temp low
and did not push the truck dt466 are realy good motor and built very well over haul is not bad it give you more miles on a good truck mine went out on 173,000 my other has 261 on it now knock on wood good luck TOM |
TeachNTow |
Too bad it ended up being your own truck... Good looking medium duty though. Good Job
Rob |
Errick Bodenheimer |
Thats a nice med duty !To bad that you own truck you had to tow!
parkerstowing |
#7 | |||
my dt466 2004 done the same thing @ 196,000 miles , we put a inframe in
parker's towing
timstruckservice |
#8 | |||
Well, It could be Worse !!! Hopefully it won't Cost a Fortune since the the Oil was Still Clean ..... Best of Luck with it & Happy New year to you
!......TIM
tator |
#9 | |||
DT 466E the reason I will never own another International. 163,000 rebuilt engine and head.
Bud |
goldcoasttowing |
#10 | |||
well at least your able to it yourself nice wrecker
OK Tow |
#11 | |||
Never good to tow your own but at least you had the equipment to tow your own.
WreckMan0920 |
#12 | |||
just done mine had 253,000 was told we got lucky it made it that long
"We're On Call For You"
harrys |
#13 | |||
i had 270,000 on mine at this point. I did the rebild myself and has been running strong since. Now has 285,000 on it
