Bald Hill Automotive |
A question for UD wrecker builders. |
I have a really nice 2004 UD2000 cab and chassis that I want to build into a wrecker. My first choice of bodies is a Jerr Dan Cougar. But, I've been told
that the air parking brake canisters are in the way of the underlift. Is there a similar body that would fit without modifying the air parking brake chamber
locations? I'd like one in the 12 ton range but I'm not too fussy.
Edited 1 time.
certifiedautomall NJ |
I would say on a UD 2000 id put something a little smaller on it maybe a 10 ton?
Mike,
Certified Auto Mall 5499 Rt 9 n Howell NJ Call if you need any help cell(732)620-3974 #1 MONMOUTH COUNTY FOR 4 YEARS RUNNING |
santiam01 |
We have done several of these. You have to reverse the backing plates & the air cans to the front of the axle. The nice thing about the UD is the parts
swap from one side to the other, no holes to drill, or parts to buy. Be carefull, those springs have ALOT of pressure on them. We factor two guys & eight
hours to do the job.
Thanks Arnott! What wrecker body would you say is ideal for this chassis? I think an aluminum Jerr Dan Cougar is the ultimate. I used to own an aluminum
Cougar and I loved it.
FMS Mike |
I agree a cougar might be a little much for a 2000 Chassis. What a great truck though! Let's get some pictures coming!
------Michael
Vibert-------
bigwolf |
![]() ![]() i have a cougar on a 1800 and its like a match made in heaven truck
and unit run out about the same aluminum body is the way to go keeps rear axle weight down also go with a 48 in. tool box in front of the bed it will still out
turn a ford chevy international or dodge with a 24 in. tunnel box
Rod Midkiff |
ok I gota ask about that tri axle that it looks like you are winching out.... ???
stay safe Rod |
bigwolf |
#7 | |||
yes i was thats showtime i stopped and helped him and rotater 60 about a year ago when i was going to ft pearce to pick up a truck we posted the job the post
was car hauler carnage 3/5/07
http://tow411.yuku.com/topic/6892 |
FMS Mike |
#8 | |||
i retract my previous statement! I guess I didn't have enough fait in the ol UD!
------Michael
Vibert-------
santiam01 |
#9 | |||
Notice how narrow the rear end is? you don't have to run flare on the UD. We have done the smaller 2" flare, but you don't need to with a UD.
