2003 NRC Quick Swap with 20K DP Winch
Miller Low Profile Cast Fork Receivers
4 Pair of Miller Cast Lift Forks, 1 Pair Tall Fabricated Lift Forks
1 Pair Chain End Caps
1997 Peterbilt 379  Large Bunk
CAT 3406E 475hp, approx. 100k on Injectors and Cam
Rebuilt 18 Speed, approx. 100k
Pete Air Leaf Rear Suspension
2-250 Gallon Aluminum Tanks
Aluminum Wheels
290" Wheelbase
GVWR 48k, 12 Front, 36K Rear
8 Michelin  11R 24.5 Tires, Good Rubber
Wet Kit with Quick Disconnects
Merritt Aluminum Cab Protector & Chain Rack
Located in Nashville, Runs and Drives Great....You need to drive it for yourself and fall in love.
Easily switch from a tow truck to pulling your sliding axle trailer or detach.
a Great Money Maker, $47,500 drives it home
Edited 3 times by R Olson 03/11/2017 1:35 PM.
