So we Braced ourselves between the Boat and a row of trees with each winch cable. Gave a little side pull to the Boat to pull her up right then stuck our water pump
in and pumped the water out.
Once the Boat was floating again we pulled her down stream to a more suitable location where we run one very large flat web sling around the whole boat. We held the webbing
up with rope and run a shorter web sling over the cabin which was fed through the large sling to stop it pulling down and underneath the hull.
She came out with no problem at all. Just kept winching a few feet at a time to allow the water and mud to drain out while she rode up the bank.
